router:~# iptables -L Chain INPUT (policy ACCEPT) target prot opt source destination DROP tcp -- anywhere anywhere tcp flags:!FIN,SYN,RST,ACK/SYN state NEW ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED DROP all -- 10.0.0.101 anywhere DROP all -- loopback/8 anywhere DROP all -f anywhere anywhere DROP tcp -- anywhere anywhere tcp flags:FIN,SYN,RST,PSH,ACK,URG/FIN,SYN,RST,ACK DROP tcp -- anywhere anywhere tcp flags:FIN,SYN/FIN,SYN DROP tcp -- anywhere anywhere tcp flags:SYN,RST/SYN,RST ACCEPT icmp -- 10.0.1.0/24 anywhere ACCEPT all -- anywhere anywhere Chain FORWARD (policy ACCEPT) target prot opt source destination ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED ACCEPT all -- 10.0.1.0/24 anywhere state NEW Chain OUTPUT (policy ACCEPT) target prot opt source destination ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED ACCEPT all -- anywhere anywhere state NE
iptables -A INPUT -d $INTIP -p tcp --destination-port 22 -m state --state NEW -j ACCEPT iptables -A INPUT -d $EXTIP -p tcp --destination-port 22 -m state --state NEW -j ACCEPTPorts for other services are opened in an identical way. If we now set the policy to DROP and reload the script, our SSH connection won't be refused. So, cross your fingers and run the script once again.
function port_forward {
iptables -A FORWARD --dst $4 -p tcp --dport $3 -j ACCEPT
iptables -t nat -A PREROUTING --dst $2 -p tcp -i $1 --dport $3 -j DNAT --to-destination $4:$5
iptables -t nat -A OUTPUT --dst $2 -p tcp --dport $3 -j DNAT --to-destination $4:$5
# USAGE:
# port_forward <service> <interface> <IP> <port> <IP> <port>
# EXAMPLE:
# port_forward Samba $EXTINT $EXTIP 445 $SERVERNAME 445The usage is dead easy. Just call the function with the correct parameters (all are required). This is where the 'Internal servers IP' section from the first part of the article comes in handy, because you can use that variable in the forwarding rules. Also note that it is quite easy to do port remapping. Port remapping comes in handy when your ISP blocks certain ports in a pitiful effort to prevent its users from hosting servers on the network. Just adjust the external and internal ports to hold the correct values, and you are set! The rule to remap the SSH port on an internal server with an IP of 10.0.1.200, as defined at the top of the script, from 2222 to 22 would look like thisport_forward SSH $EXTINT $EXTIP 2222 $SERVERNAME 22
